It's running like normal now....lol
Thats funny shit right there!!! But its only funny if it don't F things up for good. In my drinking and mechanical fix it days. I change oil in my jacked up 4x4 truck with a 350 engine could not figure out why 8 quarts of oil didn't read on the dip stick till the 9th quart over filled the drain pan and oil ran on the floor. Installing the drain plug was the fix. To many beers and good old Neil Young playing on the stereo can make a man forget what your working on LOL!!
I lost a whole roll of paper towels in the garage a couple weeks ago. Everything is running good, but I'm still a little paranoid though.
What was the problem?
Serviced air filter, and had a little to much oil inside it, so I stuffed a couple paper towels inside to soak it up/wipe it out...got distracted and set it down to do something else. Came back later and put it on with the paper still inside by accident. It sucked them into the throttle body and had it all gobbed off.
