Thanks Thanks:  17
Likes Likes:  53
Page 8 of 8 FirstFirst ... 678
Results 71 to 80 of 80
  1. #71
    Would it be wise to pull the cam plate off to check the rollers if a belt breaks?
  3. #72
    absolutely
    Quote Originally Posted by therebel19 View Post
  4. #73
    One of the things I did when I installed my sheave was to replace the cam bolts with Allen heads. Phillip head bolts is one thing that drives me nuts. It will make taking the cam plate off much easier in my opinion.
  5. Likes WV Hot Rod Rhino liked this post
  6. #74
    As long as they don't hit the cage
    Sent from JBS test site
  7. #75
    You would have to have a major problem to need a belt change on the trail..I don't carry a extra..
  8. #76
    Thanks, now I'm paranoid. I guess I'll be pulling the cover back off to double check that.
  9. #77
    You would probably hear it
  10. #78
    They did rub. I pulled the cage and it had marks on it but I never heard it. A little very light dremel work on the cage and all is good now.
ID:	13418Click image for larger version.
  11. Likes Timmi, WV Hot Rod Rhino liked this post
  12. #79
    Clutching did good! Very low in low. I did swamp the belt box so have to tear everything apart again. Sucks. I guess I need to get this thing snorkeled soon.
    Sent from my SM-G900V using Tapatalk
  13. Likes Timmi, WV Hot Rod Rhino liked this post
  14. #80
    Springs were great. I think the shocks topped out alot. Idk. But was taller and smoother so am happy.
  15. Likes WV Hot Rod Rhino liked this post
