» Today's Birthdays
Likes Likes:  2
Results 1 to 2 of 2
    777
    Hot Weather advantage upside down
    Here is a little trick with a pair of scissors in about a minute, that can help keep your bottled water cooler a little longer.
    I use a neoprene coozie on the bottom so it easily goes over the top. Cut the hole a little small so it stretches over the neck of the bottle.
    2016 Wolverine R-Spec EPS, Camo, fender ext. 4000 Moto winch w/syn rope, 14"Method B-locks, 27" Maxxis Vipr 9 & 11's, Full flip windshield, A-arm guards, 2 batts, JBS CVT grind, 16 OD, slugs, purple (all stock- Rhino is still faster)
    Brian lee Rhino450's Avatar
    Tuscola Texas
    1,612
    Good idea for winter time in west texas
  4. Likes WV Hot Rod Rhino liked this post
