Battery vs starter relay?
This morning I hit the key on the rhino and it fired up, I let it run for a while then shut it down, about ten minutes later I hit the key and it just clicks like a low battery. I through an meter on the battery and got 12.5 volts so could it be battery or more likely the relay? Could it just be the 30amp fuse (I haven't checked it yet.)
GetemDuck
A lead acid battery is fully charged when it reads 12.7 volts. !2 volts is dead. Put a charger on it, as 12.5 is maybe half discharged or so.
Timmi thanked for this post
