Likes Likes:  1
Results 1 to 9 of 9
    Belt/ clutch burn smell after JBS install
    Merry Christmas Everyone,
    hello all, new to the site and to yamaha's. I've installed the clutch and slug kit, I am now getting a clutch and or belt burning smell after doing so, especially after hard acceleration. Any ideas on where I should start looking?
    Quote Originally Posted by hutch301 View Post
    Pinched o-ring or over grease
    Sent from JBS test site
    Or if something was coming loose and the belt slipping because of it..post some pics when you tear into it
    Thanks, I’ll start there and will get some pics as well. Appreciate it
  5. Likes WV Hot Rod Rhino liked this post
    Too much grease?
    The o-ring didn’t look pinched.
    Too much grease?
    Grease looks right...new belt?
  8. #7
    No sir not a new belt.
  9. #8
    walkntall's Avatar
    Dec 2015
    Clark County, Ohio
    518
    maybe the washer wasn't up on the spines when the nut was tightened and gave it a little slop?
    2015 Viking EPS SE
    KFI Stealth 4500s
    KFI 72" Open Trail Plow
    SuperATV Flip Up Windshield
    SuperATV Side Mirrors
    Seizmik Soft Rear Window
    IR Backup Camera
    42" LED Light Bar
    JBS Extreme Sheave
    JBS Slug Kit
    Black & Gray YXZ seats
    Lots More Planned...
  10. #9
    Since you did not say, can we make assumption it is running good? is it making any chirping noises? Did you service the secondary? Is secondary shifting smoothly? Is there any grease on sheave faces (primary or secondary) from fingers?
