Fan Belt Chatter
have a 32 with air,alternator, crank pully all on one serpentine groove belt. Belt has about 1/2 in play. Every time I start it it chatters, squeals. I have tried belt dressing. Works temporarilly till next start. Belt looks fairly new. Any Good Advice ? Thanks.
Check and make sure all pulley grooves and the belt mate with same specs. Check pulley alignment and make sure they are square with the belt path. If you don't have a tensioner look at installing one and if you do have a tensioner check it for proper application and maybe get a new one. And this forum is for "hot rod' ATV and SxS toys, originators nickname is Hot Rod and a good mechanic, maybe he will have something to add.
New belt and more tension is what it sounds like it needs
