Clutch kit speed issue
So I purchased The hot rod clutch kit called James up told him what I was running on my 2007 660 which is 27x 12 x 9 ,Aftermarket 50 caliber CDI box 2 inch lift kit now I was running 49 mph with that set up. I watch every video James has made on these Primary and secondary clutch’s , the way the weights go in , how to grease them , and how to change spring . And how to install both with the new belt .. I got everything done with in 2 hours watching each video( which are awesome) as I did the install .. when all done I did my road test it would only top out at 45 mph ! I’m stumped ... today I took it all apart everything was fine and installed correctly as per his videos .. I have yet tried it on hills or mud to see any low end difference .. is this normal ?? I’m really not concerned with top speed I just want low end power for plowing and going through the woods
lighter weights, a shim, secondary spring, any of those can affect top speed
Need pics of weights and grease installed
I will have to take it back apart to get pics ... I will do a video of it
I used 18 g weights. Long side towards center Ridges up and the yamalube black bucket grease
This was my thread when I did my 660 - lots of pics and questions/answers https://hotrodforums.net/forums/show...ghlight=clutch
I think I used 15gram weights. I was running 27/9/12 and 27/11/12 itp blackwater tires. I had a cdi box. I think my weights were 15 gram. I could maintain 52-53mph on flat, more with a decline and less uphill - that's without the windshield but with a roof, hmf muffler but with quiet core installed. My profile pic shows the speedo on a flat run. I had the cdi and muffler before the clutch kit and it was in the high 40s.
Post Thanks / Like - 1 Thanks, 2 Likes
You are not gaining any motor power and with the higher gearing you may be actually lowering the power curve with less rpm at speed so that you do not have as much power to push it faster. You should find you have significant lower wheel power. Changing to lighter weights should change your shift points so that they peak at speed with the available power. Imagine shifting a 4 speed hot rod, don't shift out of the gear too quick to accelaerate faster, that is what Lighter weights will do. You may have to experiment some but James can get you started at the best point.
Thank you rodneygt that is how I installed mine but I didn’t cut the seat mount rails and I didn’t do wet clutch ...and thank you jimclemjr that clear me up on weights I’m not a need for speed guy as long as I get better low end for plowing and going through the woods ( go over downed trees and deep ditch’s ) I’ll be happy
