That price wouldn't last long by me either. And if you really aren't putting any money out of your pocket, it SHOULDN'T be a bad trade. For what you can do with it, and being into it for little initial investment, I don't think that you could really go wrong. Before I made the trade official, I would for sure test drive it and look it over to try to best insure that you are getting into something that you want.
shortbus453
Agreed.
Since it was pushing a race car, I’m sure he had it in high gear all the time and I’m hoping that did not wear out the clutch. I’ve never had any dealings with a belt driven machine, but I have heard that if it’s hesitating when you are pushing the throttle, typically it needs a new belt. Is that correct?
If it revs up before wants to move its the wet clutch
WV Hot Rod Rhino
What would be the price in parts on that if I bought it from you?
It's around 580 for everything on a 660... I can get a definite price when I get back in the office
WV Hot Rod Rhino
It's around 550 for everything on a 660... I can get a definite price when I get back in the office
Ok thanks
What is the top speed generally on that particular model?
stock it's about 40 mph
Tim87
Ok thanks
Tim87 thanked for this post
Depending on tire weight, carb settings, belt wear, clutch service life... My 2006 would only do 35-36 MPH when I first got it. With carb work and aftermarket CDI, I was able to get to 45MPH. Then with the Hot Rod Sheave and wet clutch slugged, I got to 60MPH (with light tires). When I put a little heavier tire on it would top out at 57MPH.
There are a lot of factors that go into these. It was a blast when I did my old Rhino and now one of my good buddies is enjoying it.
Timmi thanked for this post
shortbus453
Damn that’s a big jump.
Donot expect no 15mph jump with just a sheave, dont want u to get ur hopes up. U will notice a big difference on bottom end though
