Results 1 to 3 of 3
    Wet clutch nut removal
    Anyone else have trouble removing this nut? I know it is left handed threads, so I have to tighten to remove, but could not get off with impact driver, or breaker bar. Now nut is rounded off. Anyone else have this problem? If so any tips on getting it off?
    If someone put it on with red Loctite then you need to heat it.
    Put on outer primary and use a holder on it
    and try to grab nut remnant with a small pipe wrench or vise grips. Can't remember how much room is in there to get on it tho?
    You might be at the point of having to weld something else onto it now to allow the removal. Mine required a heat gun and electric impact worked.
