Hello all! I need some help. I bought an 09 rhino that the balancing shaft blew a hole in the case. I picked up a complete grizzly bottom end that I plan on using. So my question is the middle gear set is a higher gear ratio on the grizzly. will the grizzly middle gear bed alright to run or should I stick with the stock rhino mid gear set. Has anyone run grizzly gears in there rhino?
My plan for the build is crank works rebuilt crank, 734 big bore cp piston and stage 2 cam plus all the other little stuff to go along with it. Any input is greatly appreciated, Thanks!
