My diff lock doesnt always spin both front tires????
Anyone else run into this problem??
Sent from my iPad using Tapatalk
Using Tapatalk
Can you hear the actuator engage from 2 wheel to 4 wheel then to lock? Does the switch LED come on in lock?
If you can hear the servo motors working , try changing the diff oil . Mine was getting "sluggish" coming out of 4x4 ...changed the oil , and it started working right .
When I first bought my Rhino my diff-lock was not engaging. I turned out to be a bent shift fork.
06 Rhino 660, JBS sheave, Dynatec CDI, 27" Mud Lite XTR, and some other crap.
If your led indicator is flickering or going dim you may have a shorted servo,also check the switch connections for corrosion,take out the switch first ,clean and diaelectric grease and reinstall
AJ's SXS Accessories 304-575-0342
For Accessories / Help and or Questions and on Facebook @ AJ'S SXS Accessories
Website address www.ajswildcataccessories.com
Facebook https://www.facebook.com/pages/AJS-SXS-Accessories/219547124736474?ref=br_tf
