Want your rhino to run cooler or simply just tired of turning that fan switch on you wired in to make it run cooler? If so the problem is solved with the Mello FAB cooling fan control. It’s an independent control system that bypasses all the factory controls and wiring to turn your fan on at the 188 range. https://youtu.be/cpuOvARlg5I
