» Today's Birthdays
wrfd77 (43)
Likes Likes:  2
Results 1 to 2 of 2
    cam gear bolt dropped down the cam chain sidee
    cam gear bolt dropped in the engine when checking everything. The engine has not been started or anything. I have turned it over with a ratchet and the damn bolt won't show itself. Any ideas?
    I have the stator off and the cam cover off. I am going to take snap ring pliers and the next gear off next if anyone has a better idea please let me know.
    It is not in the oil pump sump. It was dropped after a test fire of the engine to put lock tite on it.
    got it, it was stuck behind the guide for the oil chain, had to loosen it and it fell right out!
  3. Likes JoshK, jimclemjr liked this post
