Likes Likes:  1
Results 1 to 2 of 2
    16 Viking secondary sheave HELP!
    A year ago I purchased a used 16 Viking with 15000 miles on it. 500 miles in heard a terrible noise while driving. Come to find out that one of the clutch cover bolts came out and wrecked havoc on the sheaves. I used this as an excuse to order me the JBS hot rod extreme clutch kit with spring. Got everything on the primary done and wet clutch slugged. Went to change the spring on the secondary and discovered that the bolt got down in there too and it’s pretty tore up. I feel that the sliding sheave needs changed but idk on the fixed one. Attached are pics of the damage. Click image for larger version.
ID:	13844Click image for larger version.
ID:	13845Click image for larger version.
    10,102
    call James at JBS Peformance, 304-673-2602, he can help you with it
  3. Thanks WV Hot Rod Rhino thanked for this post
    Likes WV Hot Rod Rhino liked this post
Tags for this Thread
