So far i like them they go good
Sent from my SCH-R760 using Tapatalk 2
07 sport 720 stroker, +4mm hot rods stroker crank ( welded ) weller head studs, 43mm fcr carb,alba high flow fuel pump, weller high flow fuel line kit, billet middle drive support 102mm 10:1 JE piston stage 1 raptor cam, ported & polished head & intake manifold, k&n full intake, alba exhaust, 700 cam plate JBS sheave 14g od's orange spring antifriction washers,700 belt, rhino giant 4 seat cage, 26" big horns on raceline beadlocks, homemade diamond plate alum. half doors....an more!
Nice I really like my alba pipe.
Finally got a day off an finished puting the rhino together took it for a spin lastnight in the snow/ice man it is fun it goes awesome played with the tuning some it was running a little rich mid range still have some tuning to do but ill pick away at it its pretty close now.the alba pipe glows pretty good at night lol but from what ive read this is pretty normal when running it hard. So far shes running strong! My plow truck died so i guess im puting a plow on the rhino going to pick it up today an mount it.
Like that new shiny exhaust system. Glad you've got sometime to try out that new power house.
I get off work in an hour and will hopefully be running mine up to the mountains to give her hell.
glad yours runs good and hopefully mine does too.
thanks guys. good luck crusty hopfully yours runs like a champ!
well had a chance to tune the rhino alittle more today i was alot leaner than i thought did a wide open run down the road an back pulled plug an it was white..very white waiting on a few pilot jets to get here but i drilled the slide holes out to 1/8" an put a 172.5 main in it an it still wasnt enough right now im up to a 182.5 main 45 pilot 3 turns out on air screw an i run a constant 12.2-12.9 on my wide band so im pretty close now going to bump the pilot up to a 50 or 55 when they get here an see what that does.
Looking good!
nice!!!!
